Painted tiles, oil and flies!
12 Jan 2010
Kent
Several months ago I painted the ceramic tiles in my bathroom using Zinsser bullseye 123 water based primer, followed by two coats Zinsser perma white interior eggshell. It's solid and held up perfectly almost everywhere, including where it's constantly saturated by the shower. There are two areas where it's failed, which is on a ledge where the tiles are also painted and bottles, shampoo, etc. is kept, and the worst area is the window head. The window head is the worst, with the paint badly cracked and it moves/slides when touched. It also feels oily and tiny little gnat type flies have stuck to it. The two reveals and cill are fine however.
Why does it do this, I can think only that the steam from the bath is rising up and becoming trapped there? Is there a different type of paint I could use that will be unaffected by moisture (even though the perma white claims to be)?
