Hi All.
Is it possible to paint the frame of a gas heater similar to the ones in the links below? If it is, would special paint be required or would ordinary paint suffice?
The following picture isn't very clear but if you can make it out, there are four parts on this heater.
http://www.appliance-direct.co.uk/products/small/misermatic.gif
1) The brown wooden frame (which normally has the cut out to accommodate the heater control knob).
2) The brown metal face at the front of the heater.
3) The silver metal part at the front that has the protective grille across it.
4) The white parts that get heated in the centre.
Note that I am referring to the actual parts of the heater itself and not the surround of the fireplace that is in the picture.
The parts that I want to paint are 1 and 2 above.
Another clearer example, but not as similar as the one above to the one which is to be painted:-
http://southnorthamptonshirelibdems.org.uk/news/images/Gas Fire.jpg
If it is possible, any advice would be appreciated on which paint to use and how to paint it, i.e preparation, coats, etc.
Thanks.
Thanks.
