painting close to the edge on ceilings
26 Jan 2008
All,
I would appreciate some help on painting up to the edge of ceilings. I have been using a roller on the main part of the ceiling but have been applying the paint at the edge of the ceilings using a 1 inch brush.
Trouble is, I get a shed load of ceiling paint onto the walls. I have been “stabbing” the brush into the joint between walls and ceiling. Should I be applying paint this way, or should I brush it along the edge of the ceiling???
Bearing in mind that the walls will be painted in magnolia (ceiling is white), following the ceiling, does it really matter if when painting the ceiling I get white paint on the walls, as it will later be covered in magnolia???
Cheers
Sub
I do not think you should worry about the white going onto the walls. The wall paint will cover it ok as long as you using good paint aqnd using correct number of coats.This is my experience anyway.
Cheers for your help, any other pro's want to add anything into the pot?
It pays to come down on to the wall, this will give you a clean edge to cut in to when you paint the walls.
I didn't undersrand your stabbing idea.
I use a 2" or 4" brush, whatevers to hand, for the edges, and hold it at a slant to get into the angle. It's fine to get ceiling paint on the walls as you will be painting over it, but you have to be a lot more careful not to get wall paint on the ceiling.
Stabbing seems bound to make a bit of a mess and you'll have to use a slant or some other method when doing the tops of the walls.
If you get a 2" Anza brush from B&Q you'll find getting a good line is a doddle.
