Painting directly onto SE plasterboard
4 Aug 2006
Lancashire
Hi
I want to try and avoid plastering the square edged (wrong one...! should have been tapered) plasterboard I have just put up on my bathroom ceiling and walls. Does anyone have any tips on getting a really good finish and hiding the joints and screw holes.
Cheers :D
dONT TRY AND FILL IT IN ONE GOT...BUILD IT UP ON THE JOINTS
mAKE SURE THE NAIL HEADS ARE BELOW THE SURFACE
i FILL THE GAPS FIRST THEN PASTE THE TAPE ON..im not experience enough to joint boards properly.
The caulk over the top
Sorry about the caps..ive just looked up and seen the caps lock on...ad im not re-typing it!
Hi Zampa
maybe I did not explain very well..... ! I have put up square edged plasterboard and want to know if I can fill the joints and just paint it. There
is no space for jointing tape as it would be raised and visible. Would the joint be prone to cracking if no tape was added?
Im affriad not...when it all settles into place and the wood shrinks or expands you will ed up with cracks..
You could trying lining paper though, one you have filled the joints, double line it for good measure
Thanks for that Zampa
I have decided to skim it after all because I think that will be the end result anyway
Cheers :D
