painting exterior windows
18 Dec 2005
Clackmannanshire
Maybe a silly question but what type of paint is best to paint the outside of my wooden window frames, and will they need primed or undercoated?
thanks for any help
What type of wood are they ?
Are they new ?
Have they been coated before ?
If so, what with ?
Do you know what type of wood it is ?
Is it Pine ?
Do you know what they were painted/stained with before ?
think they're pine, I am not sure what they were painted with before but it isflaking off in big flakes it looks like eggshell paint, if there is such a thing
You must remove all the old flaking paint first whatever you do..
Use a hot air gun..the heat is easier to control around the glass
When you have done that give all the bear wood a good rub down and apply knotting to any bare knots..
Then prime, using either acrylic primer undercoat or thiined out oil based undercoat,..or even oil based wood primer..
Then rub down again, undercoat twice and then gloss..or use a exterior satin if thats what you prefer.
If it is oil based eggshell then thats probably the reason its blown...normal eggshell isnt flexible enough to cope with the movement of the wood.
thanks, it's more than a lick of paint then. I think I'll do one window at a time. Can you tell me how much time to leave between coats, and if it rains between coats is it all ruined thanks for the help everybody
John
You need to follow the instructions on the can for that one..
Take it from a professional you've got a big job on your hands there.
Zampas right you do need to remove all loose and flaking paint first with a scraper and heatgun (careful u don't crack the glass!!), then ideally you should use dulux weathershield primer (its a blue colour!!), a flexible wood filler (ronseal and polycell both do these), then a coat or two of dulux weathershield undercoat and finally your topcoat of dulux weathershield gloss.
If you spend a bit more time (and money) doing it properly now it'll last longer so it won't need doing again for a good few years.
I'm a decorator and i've done many outsides in some terrible states.. i have a website which i'm regularly updating with tips and reviews. I'd appreciate some requests for advice which i can include.
There is also a windows care system product that you use like filler but is 100 times better for outside work and is guaranteed for life. Its crazy stuff but great for withstanding the elements.
Thanks alot.
Moderator's note:
Advertising links removed
Mod Rupert
