One of my back walls, which is painted, had a nasty damp problem (wall turned out to be a closed off chimney, which wasn't quite closed off so had been leaking for years).
The damp issue was sorted last year and although we wanted to paint the wall due to excessive damage to the paintwork and the pointing, so we were advised to leave it to dry for a year or so, which we have done.
There's still quite a lot of damaged paintwork on it (bubbling and flaking) which I'm going to remove this weekend, then re-point.
Once that's all done, I need to repaint the wall and wanted to know what I should do to the wall in preparation (base coats etc) and also what kind of paint would be best to use (breathable etc). The colour needs to be white to match the rest of the terrace.
Thanks.
Thanks.
