Painting kitchen walls
3 Dec 2009
Yorkshire
Hello
I'm planning on painting my kitchen walls over the existing white matt. Now its been a few years since i painted it so just need some advice on the best way to prepare the walls. I'm thinking about sanding lightly then sugar soap. Is this right? If sanding is needed, what grade would be best?
Phil
I'd sugar soap first, then a good firm sand once dry. Make sure you rinse the SS well to avoid any problems. I always recommend eggshell for kitchens, you'll find it labelled as kitchen and bathroom in the sheds.
Thanks for your reply.
May i ask why wash then sand? I was under the impression to sand then sugar soap as this will clean away the dust produced by sanding.
Phil
The reason you wash with sugar soap first is to remove grease and contaminants which are often found on kitchen walls. If you sand first and sand over grease you'll clog up the abrasive and get in a mess.
Rightio :) So sugar soap first then sand. Do i need to just wipe the wall down after i've sanded. With the other walls in the house is just sugar soaping enough?
Phil
You can wipe it all down or dust it off. As for the other walls, if they're dirty use sugar soap and if they feel rough give them a good sand down.
What grade of sand paper? Also whats the best method to sand a wall? I would imagine using a sanding block would take a while!
Phil
