I will be ordering this cladding from Interlam to cover an internal wall. The cladding is made from 19mm MDF board.
I would like to achieve a similar finish to that in the images on the Interlam site where the high-flat-points are a darker colour to the recessed parts of the pattern.
The MDF will arrive unfinished, hence I'm looking for the following pointers:
1. Should the MDF be primed prior to painting?
2. I will be spray-painting the entire boards first in order to achieve a smooth finish. What type of paint should I use on the MDF? The rest of the room is painted with Farrow & Ball Emulsion. Can I use the same emulsion or would I require a timber paint?
3. How would you go about painting the high-flat-points a different colour? I'm thinking a very firm and wide roller would be best in order not to get paint onto the recessed parts? But what type of roller for a smooth finish? Or is there a better way of doing this?
Any advice much appreciated .
