Hi - I've just started painting gloss paint direct onto a new white finished MDF windowsill (not a shiny finish - as if it's got matt emulsion on). Stopped because it's soaked straight into the end and front edge - the top surface looks fine. I've painted about 30cm and now I see that I should have put a primer on first. Will it be ok if I just leave it now and come back to prime it? What would you use to prime it with? Can I use 50:50 emulsion/water to save cash - or is it not worth it?
