I'm repainting all the windows in my house white - inside only - they are currently a reddish brown woodstain.
I've completed the first room but I'm not happy with the finish. I used Zinseer Coverstain to ensure that the woodstain would never bleed through, and then Zinseer Permawhite Interior Semi gloss as the top coat. This was tricky to apply and left horrible brush marks unless a heavier coat was applied in which case it ran terribly. Surfaces were rubbed down between coats......
Any ideas on the best combination primer / top coat. I want a hardwearing surface that stays white and does not yellow over time. A friend recently mentioned Farrow and Ball gloss - this is a water based alkyd paint which is meant to be far superior to the water based acrylics. Has any ones used it or have any other thoughts?
