Can anyone tell me the best way for DIY pebble-dash painting..I'm a novice and don't fancy the possible damage to neighbouring property caused by spray-painting!
Do I need to wash the pebble dashing?
Best to use Pliolite Resin Based Masonry on top of pebbledash. This is due to painting over two different surfaces being the pebbles and the render. You need to thin down first coat though as per tins instructions.
