Painting Stripped Walls
7 Nov 2006
Can you please help.
I have stripped my walls of wallpaper and would like to paint the bare plaster rather than repaper. I have filled and sanded all areas that required attention and from view they look ready for paint.
My question is do i need to seal the walls with say a primer sealer or pure oil based paint to stop the paste which will obviously be present within the plaster surface from reacting with my water based emulsion paint.
Ultimately i don't want to start the job and realise i should have sealed the paste into the wall before trying to put my finish coats of paint on the wall.
You wont need any special primer sealer, but what you must do is wet the walls in and scrub and scrape them until you are certain you have got rid of all the old paste that has soaked into them
If you dont the paint will bubble up as soon as it goes on, causing you untold grief..
Once the walls are clean then you can first coat them with a mist coat approx 20-30% water in your paint.
Clean with some sugar soap yes.. but the key to it really is to give the walls a really good rubdown with sandpaper before you paint.
They should be fine after that.
Moderator's note:
Advertising link removed
Mod Rupert
