Hi, I have been painting a room and decided to paint over the wallpaper which has worked out fine. one problem is the edges, brush painted under the coving, above the skirting along the sides and filled in with a roller, but am left with the edges noticeable after 2 coats, is there anything i should have done differently or can do to rectify, if i keep adding coats will it look the same
ta
ta
