Hi all,
In my past house I've had good results using easi-fill after removing wallpaper when I wanted to just paint the walls.
Now my problem this time is in our new place I've removed the wallpaper in the living room but the walls are now a mixture of old paint, plaster board and a little bit of damaged plasterboard were the top part of the plasterboard paper has come off with the wallpaper leaving brown patches (not deep).
My overall plan is too seal the walls, easi-fill, sand, latex primer, then two coats of paint.
Now I'm unsure of what to use to first seal the walls before easi-filling. I've read about zinsser gardz which looks good but it's a little expensive (£33) at my local crown centre. What alternative are there if any to seal the walls, especially to seal the damged plaster board? Some kind of oil based primer?
I now it#s best to re-skim but I can't afford to get the walls re skimmed at present.
Anybody have any advise regards what to seal the walls with and if my plan sounds ok.
Thanks in advance.
Thanks in advance.
