Palisade Fence follow contour or fit horizontal
15 Jun 2004
Norwich
I am erecting a fence round a veg patch to keep the dog out. It will be 24ft long (4 sections of fence), there is a slight incline maybe about 15/18", I asked the fella where I bought the fence regarding the slope & he said let the fence follow the slope, if I do that do the posts go vertical or at the angle of the fence.
I still may fit it horizontal & just raise the first 2 fence panels & cut the base of the last 2.
Any advice tips welcome, thanks.
Steve
These are assembled panels, I have just stood them up in the garden both following the contour & leaving a gap at the bottom. Both ways look ok, but I am thinking follow the contours should be the easier way.
The fall is greater than I originly thought its about 2ft, so If I dont follow the contour I will have to get longer posts for 2 sections.
for panels you will have to have the posts vertical and go down the garden in steps.
Concrete or bricks at the bottom to fill in the gaps probably best.
If you go with the ground, how will you ensure all sections fit?
I would have thought easier to go straight and as above fill with brick/cement at the bottom. This will also keep the timber sections well off the ground.
Problem is its across a lawn, so I dont think it will look that nice if there are bricks at the bottom.
I followed the contour.
Set the first post yesterday & then fixed the fence & dug the remaining post holes today.
Checked it was square & looked to see that it was looking ok. Then poured concrete into holes.
I've got a thumbs up.
I suppose a couple of photos are completely out of the question?
