Pan connector
9 Jan 2010
Bristol
Hi - I'm plumbing in a downstairs loo and sink. The sink waste needs to go into the same waste pipe as the loo.
So, do I carefully knock a hole in the pan connector and connect the sink waste to this, then seal around it? Or is there some other way - for example I wonder if there are pan connectors with knockout sections for just this purpose?
Tnx in advance,
Justy :confused:
is the pan connector facing down straight back into the wall or sideways to the left or right? you can buy bent pan connectors with 1 1/2" connections built in
Hi - the toilet pan outflow is horizontal and the hole in the floor is vertical. So I was going to buy a 90-degree pan connector - ideally with a punchout 'boss' somewhere on it so I could connect the sink waste here.
I haven't actually bought the connector yet and that's what I was trying to get my head around as there seems no other way of connecting the sink waste to the vertical soil pipe which is just a hole in the floor behind where the toilet will be sited.
I'm a bit concerned that if I don't do it right that toilet waste might flush up or block the sink waste pipe, depending where I join the two things together. Maybe I'm just worrying unnecessarily but want to get it right first time :cool:
Tnx for advice,
J
Got one :D surprisingly my local b&q had one tucked away on a shelf with a 32mm boss thingy on it for the sink waste - woohoo.
Tnx for all the help,
J
