Hi
Any comments appreciated, the tv stated was working fine then the mrs said she looked up and the sound was still on but no picture and then the sound went off. When you put power to the tv (plug in mains) the led does not do the 10 flashes I have read about, when you press the on switch the red led comes on solid, then when you turn on by remote the led flashes green a few time then comes on solid green the screen has a slight glow which can definitely be seen when I turn the living room light off and all four fans are running. Then when you turn to standby by remote the solid green led drops to solid red but the fans can still be heard running and the slight screen glow still visible when turning room light off. Turning off the tv by normal power switch on front panel does turn the tv off completely. I have had the back panel off, carefully hoovered everywhere to give a clear view of everything and nothing looks obvious (no swollen caps or anything), I also completely removed the main power board and looked both sides of it. Put everything back and there was stil no change, everything the same as described.
Thanks in advance
Neil
Thanks in advance
Neil
