Bit of a two part question here.
I'm looking to panel the bottom meter of my living room with tongue and groove pine with a floor grade varnish finish. The problem is that there is a radiator in the way.
And now the questions
1) Will the heat from the radiator warp or adverly effect the timber, I'm going for a rustic effect so a little bit of shrinkage/cracking won't be a problem... I'm more worried about bowing/finish falling off (I know this is kind of a joinery problem, but plumers probably have a better chance of having see the effects of radiators on panel).
2) To panel behind the radiator, I will need to remove it, panel round the brackets and re-install. How does one bleed the system and then lift the radiator off, and then, replace it.
Cheers, Sam.
Cheers, Sam.
