Panic button keeps activating
25 Oct 2016
I got an optima plus2 system this as happened twice now first time on the 11/4 I turned on kitchen light panic button went off and now today came down Turing off alarm at keypad turned hall light on and panic button went again .but this time it would only reset after about 20 seconds I'm gonna loop it out later but has anybody come across this before and would the lights have anything to do with it .and battery is approx 2and half years old thanks
Check for a/c induced volt
Put multimeter and a/c range positive probe on +dc terminal and negative probe on earth if more than 1.2v a/c this could be a problem
You then need to if a filter
Gonna try to get meter until then if I loop out will it still activate ? This problem as only just started had system for bout 20yrs .
Yes link out
Try switching LIGHT switch on and off quickly,if still trips could be induced voltage.
