I think we've all worked out that 'noseall' knows nothing about smart meters...sounds like you didn't understand anything.
And one of his disciples is blooming ignorant as well
That revived memories from the distant past, as I recall all uses of silicone ( including thing like silicon rubber etc ) were to be avoided. The vapour attacked metals used for contact pads in relays. The approved lubricant for mechanisms was a graphite based mixture known as Oil-dagDid you know that BT had to ban the use of silicone floor cleaners in exchanges before it all went digital.
I'm not but feel there should be a lot more info on faults around when there isn't. Also contradictions at times. I quoted some from the BBC link.And one of his disciples
If that was the case then how would the In House Display know the correct price per kWh to use when calculating the cost.
So not turning off supplies in the millions? Nice find...The latest figures show that nine in 10 smart meters are working fine. But a recent survey by Citizens’ Advice suggests one in five households have had to regularly send manual meter readings because their smart meters haven’t worked properly.
It also said that a recent customer experience survey by Ofgem “found no statistically significant differences” in the proportion of customers reporting that their meter was not sending readings to their suppliers for areas in, or predominantly in, the north.
Harry’s in a mood today.
I wouldn’t push him too much.
Nice set of contradictions though isn't it.So not turning off supplies in the millions? Nice find...
If that is the case then how does the meter get to know the current price per kWh ?From the meter of course.
Shame. We can all come up with theoretical scenarios, but if they don't happen in the real world they are pointless.
I deal with and use tech all the time. I am not against smart meters in general, but against the ****ing stupid designs and systems we're getting lumbered with, and the attitude of those pushing them.Switching to SM is inevitable. The luddites and the morons can go into fantasy over-drive.
Each meter has a nominal service life. When your current meter reaches that time, they can contact you and inform you that they are going to change your meter - I think they are legally required to change it. You'll find that they won't then fit a "dumb" meter, so your choice will be to accept a new "smart" meter, or be disconnected as they can't legally supply you. As an end user, you do not have any choice over the meter the supplier (or their contractors) fit - your legal rights are only that the supplier's meter must be accurate. If you refuse to have the supplier's choice of meter installed, then they have a right to not install one at all and leave you unsupplied if that is your preference.So I can be made to accept a smart meter when I pay my bills on time ?
Please show me the proof or off you pop
Which, unless you let them in voluntarily at their first visit, means they then have to go back to court for a warrant for forced entry. Which shows that claims that there is no difference in process for smart and non-smart meters are "incorrect".With a "smart meter" that has the disconnection relay there is no need to visit the meter location,
So good for you, your sample of one went well, therefore you extrapolate that to mean no-one else ever has a problem.We've just taken over a large warehouse which had been vacant for some time. Electric smart meter was "de-energised" as not in use. One phone call and voila, power on again.
That is quite dishonest, I have never claimed that "no one else ever has a problem".So good for you, your sample of one went well, therefore you extrapolate that to mean no-one else ever has a problem.
So what. Things happen and need to be attended to. Such is life...
