- Joined
- 12 Jan 2013
- Messages
- 20
- Reaction score
- 1
- Country
Hello, i want to connect two N.C magnetic contacts using parallel wiring in the auxilliary input of the Visonic MC-302E PG2?.
From the manual of the MC-302E PG2:
a.If the auxiliary input of the MCT-302E PG2 is defined as a Normally Closed (N.C.) type, series connected N.C. sensor contacts must be used exclusively. An E.O.L. resistor will not be required.
b.If the auxiliary input of the MCT-302E PG2 is defined as a Normally Open (N.O.) type, parallel connected N.O. sensor contacts must be used exclusively. An E.O.L. resistor will not be required.
c.For E.O.L. supervision:
Normally Closed (N.C.) sensor contacts can be used. A 47kΩ E.O.L. resistor must be wired at the far end of the zone loop.
Can i use a different resistor in the first magnetic contact using this parallel wiring?
Let's say a 2.2k in the first and 4.7 k in the second ? Would this cause a problem?
In that case i'll have two zones ?
Thank you very much.
