Hello all.
Ok firstly here are some photos of a parapet wall on a coach house I recently bought and some questions. All advice taken seriously as I am about to have internal wall insulation installed and so need to fix asap.
The facts:
1. Water ingress as salts seen in corner below the end of the parapet
2. I lifted a slab and no DPC.
3. Lead only on inner side of wall and undercuts only about an inch.
4. I previous put weather seal paint on top just as an easy fix last November. That's the white stuff. I appreciate i might not do much.
5. It is solid brick as you can see.
The Questions:
1. Is the water really soaking through these stones or is likely to be running off and then through the brickwork?
2. If through the stones then should it remove them all and put a dpc down or lead cap the lot? Ideally I don't want to have to remove them all and pay to have scfolding put up etc. This one stone took enough work to clean the old mortar.
3. Would that Acrypol Paint be a good 'medium term' solution to created a barrier.
[/b]
The facts:
The Questions:
