9 months ago we had a new carpet laid in the lounge and the carpet fitter used an underlay called Cloud 9, which gives a real good feel to your carpet but has a plastic membrane on the bottom
We noticed the other day a lump in the middle of the lounge, after lifting the carpet (what a pain that was) we found that the parquet floor had bowed due to expansion. Checking the cork filled expansion gaps around the skirting boards I was surprised to see that they hadn’t moved or been squeezed.
We believe this parquet flooring has been down since the house was built back in 1950 and when we bought the house there was already a carpet down and we replaced that about 10 years and when we had this carpet fitted there was no sign of bowing, we did however have the green rippled type of underlay before but this cloud 9 stuff does make the room very warm (very good insulation)
The carpet fitter said that he has never seen this in forty years of fitting carpets but the only thing I can think of is that the plastic membrane on the underlay has caused the parquet to sweat as its on top of a concrete floor so has expand more then before.
Has anyone else ever come across this or maybe could suggest what might have caused it.
Cheers
Cheers
