Hi Im new to this forum,
I have a project on the go at the moment putting down reclaimed parquet flooring... It's almost done looks great but I have run out of the parquet fingers!
The summer house has what I believe to be a teak/mahogony colour wood finger parquet, possibly oak but doubt it
The finger dimension are
152mm or 15.2 cm in length
9mm deep
25mm or 2.5cm wide
I bought what I thought was more than enough... as they say you can only learn!!!!!!!!!!!!!!!
For me this did not apply as I bought some rclaimed oak finger parquet to floor the newly extended kitchen, and again Im short on parquet fingers!!!
This time the dimensions are
115mm or 11.5cm in length
23mm or 2.3cm wide
9mm deep
I believe this to be oak parquet as the wood is much lighter than summer house parquet although they have a similar grain??
So if any one knows any one selling parquet flooring either new or used which is the same dimension then let me know, or if you can advise on what the wood is likely to be?
Many thanks
r
[/b]
9mm deep
25mm or 2.5cm wide
23mm or 2.3cm wide
9mm deep
Many thanks
r
[/b]
