Hi, I have project to remove badly damaged/maintained bitumen bonded parquet flooring, approximately 20mm thick. The original screed (about 20mm thick) has a bitumen DPM, however this was only evident around the chimney areas. I cant be sure for the whole floor.
We are planning to install LVT or engineered wooden flooring as the replacement.
I am looking for some advice on how the bitumen should be prepared and what are my options of products to use on top of the prepared bitumen. It will also be beneficial to install a new (or additional) DPM at this stage
If I go with LVT, there will be a level reduction which will cause an issue at the stairs and under the doors etc. I might be able to get away with it by using engineered flooring, however engineered flooring is not my first option.
I appreciate any input
