Evening,
In the process of changing my gaps in bathroom basin.
On the underside of the existing tap is a flexi metal pipe which then joins to the copper pipe etc.
I've changed the cold tap but noticed the flexi pipe is about 1/4 inch from screwing on.
Reason being is that the threaded part that on the tap that passes through the sink is just a touch shorter than the old ones I've taken off.
So is there such an item that I could add so then I can fit the flexi pipe.
Thanks.
I use Screw Fix and Toolstation.
Thanks.
