One for those who enjoy interpreting officialdom.
I want to install a socket into an existing ring main. Very easy job. The ring runs right past where I want to put it and there are two accessible sockets relatively close either side. I will need to extend the ring very slightly to reach the position of the new socket.
To avoid using JB's my plan was to remove the T&E linking the two existing sockets, trim it to reach the new socket on one side and then run a new length from the new socket to rejoin the second existing socket, hence partially extending the ring (by about a foot!). All neat and tidy. Cables in safe zones etc.
Under Part P it seems that I can add 'socket-outlets or fused spurs to an existing ring' or I can replace cable, but only if it is damaged (!). Any work involving 'provision of new fixed cabling' seems to be notifiable, although this is then made ambiguous by additional note H to tables 1 & 2 which says 'fixed wiring AND the installation of a new circuit'.
So, is my new T&E run to the old socket outside of compliance? If so, could I technically comply, by moving the socket slightly and stressing the existing cable (which I obviously won't do)? Also, how the hell would anyone install a spur without fixed cable?
If this is the case, I could presumably 'accidentally' drive a nail through the existing cable (I am going to be very lucky and anticipate that my ham-fisted hammering will take place when the power is off) and replace it quite legally, and install a socket at the same time...
Am I missing something here?
