Our boiler heats both the Central Heating and hot water tank. The timer is set to operate them at separate times; generally the CH is set to come on early morning and then the evening. The hot water is set to come on late PM ready for showers the next morning.
We have found if there is a demand for both simultaneously, then the CH works ok but the Water does not heat and hence we’ve set the timer to operate them separately.
Our problem is that if we boost the hot water, say during the day, and that completes, then flick it back to CH, only the upstairs bedroom radiators heat up. **The upstairs bathroom and ALL the downstairs radiators remain cold**
With only the upstairs bedroom radiators coming on, the flow circulating soon gets too hot for the boiler’s internal thermostat and so it turns off (as it should). The boiler comes back on after a short time, but the flow still only circulates around the bedroom radiators.
In order to get the flow circulating back to ALL radiators, I have found if I turn off the heating demand for 40 minutes, I can then flick on the CH and then all radiators heat up as normal.
I thought it must be some upstairs valve/switch getting hot which then stops the flow to the downstairs, however on the odd occasion, when the CH demand comes on in the morning, only the three bedroom radiators heat up, despite the hot water demand not having been on since the night before, albeit the Water was the last thing to operate.
All radiators work a majority of the time, balancing seems ok and I can hear the pump working all the time there’s demand.
(I am not a heating engineer so limited on testing I can carry out.)
