I want to put an en-suite in two rooms, in the alcove area between the wall and the start of the chimney breast isnt' quite big enough, I Want to remove about 300-400mm of the left hand side if the chimney breast.
What supports if any would I have to put in. Effectively I'm cutting into the chimney breast at one side. In fact in a victorian house with nearly 11 foot cielings I don't need the full height of the breast portion removed either.
My initial thoughts are to put a bit of steel lintel in like a big flat RSJ maybe halfway through the breast, and/or maybe one gallows bracket under the removed portion of the breast.
What might building control require in these circumstances.
I know its only 300-400mm but it just makes all the fitting of toilets and showers so much simpler if I can have a straight run over 6 foot ish!
so the breast would look sort of like below when viewed from the front:
[code:1]
_________ ========
new | ========
ensuite | ========
here | ========
[/code:1]
hope this graphic makes sense....
[code:1]
_________ ========
new | ========
ensuite | ========
here | ========
[/code:1]
