Partial Trench Block Vs. Trench Fill
22 Jun 2015
Starting digging our single story extension on Monday and that means ordering concrete. I need to dig down 1m deep, and to tie in with the current house I figured I'd finish concrete 1 brick below ground. Which means I'll have 3 bricks in total up to DPC (1 below ground, 2 above).
But my digger driver said it might be worth using trench blocks to save a little on concrete.
I worked it out as D: 450mm * W: 600mm * L: 18m, which works out to 3 cubic metres, or 432 GBP.
Alternatively I can lay 41 of these Toplite Aerated blocks of L: 440 * W: 300 * H: 215, which would cost me 180 GBP.
That's a saving of nearly 252 GBP, which might be worth the extra work. I might even consider two rows of these blocks to save a little more, but won't go further to save my back.
Is there any reason not to use these? I assume Building Control would be equally happy with me filling my trench with:
  • 925mm of concrete + 65mm brick & 10mm mortar joint to make up the 1m to ground level, or
  • 710mm of concrete + 215 trench block & 10mm mortar joint + 65mm brick & 10mm mortar joint
  • 485mm of concrete + 2 * (215 trench block & 10mm mortar joint) + 65mm brick & 10mm mortar joint
I used the minimum concrete and built up with blocks. The equation is obviously different when your DIYing, especially in summer. You may also get away with backfilling with some of what you've dug out to save the cost of removal. But beware any minimum quantity/charge on your concrete delivery.
Do you not need 450mm below ground level for frost cover?
