I wish to reinstate the partition wall between the kitchen and lounge area. The width of wall is approx 4ft. Should I use concrete block or erect a stud wall to this?
There is part of the partion wall already in existence (concrete block). I was going to attach the stud wall to this using chemical anchors and also attach to the floor with expansion bolts and screw into the ceiling. Would this then support a door?
