- Joined
- 9 Apr 2024
- Messages
- 9
- Reaction score
- 1
- Country
Good Morning,
I have an integral garage which is double skin contruction where part of the main house (about 1500 mm) and then single skin with piers for the protrusion. The upstairs wall is supported by a concrete lintel. The floor is concrete and stepped down from the main house.
I am thinking of placing a stud wall underneath the lintel to create a cloak room and put a washing machine and dryer in there. The main drainage stack is in the corner.
My outline thinking for the stud wall is a twin stud on top of block with a damp course to create a cavity for a sliding door (saves space), studs filled with celotex/kingspan, overboarded on the house side (if needed) and the plaster board. The garage side will have fireproof board. Of course this hinges on getting a sliding fireproof door (no pun intended).
The bathroom is above the would be cloak room, hence my desire to parition at the lintel as the garage is a massive cold sink.
In terms of this:
1) Do I need any form of building control sign off or similar?
2) The gas meter is in the would be cloak room/washing machine room. Does this have any impact on things?
3) Does the stud wall plan sound reasonable? Is there anything I need to consider?
4) Any hints and tips that would be useful?
Thanks in advance.
In terms of this:
Thanks in advance.
