After some advice
I want to partition a proportion of my integral garage to create a utility room for a washer and dryer (condenser). The garage is at the front of the property and the kitchen at the rear with a stairway in between.
It will be necessary to plumb the waste from the garage, under the stairs into the kitchen, however this means running waste pipework behind the oven.........????? is this a problem due to heat or can I put a heat shield over the piping to protect it?
I was thinking of using a Sanivite waste system...anyone have any opinion on the performance of these units.
Also I will need to knock a new doorway into the garage from the hallway as there is no way into the garage from the house at the moment...any advice on building regs etc..?
Paul.
Paul.
