paslode finishing nailer fault
19 Oct 2013
Nottingham
hi, i have a fault with my paslode finishing nailer. when i press the trigger the battery light flashes red and green and wont fire, when i remove and reinsert the battery it flashes green again until i try to fire it then it flashes red and green again. many thanks in advance guys.
Have you tried a different gas canister??
When was it last cleaned properly??
If you put the battery on the charger what light sequence do you get
Does the gun start to load with gas then stop when the lights come on or do the lights just come on
thanks mate for the help. all is well with the gun until i either plunge the nose down and it flashes red and green, then i take and reinsert the battery so it flashes green then pull the trigger and it flashes red and green. the batterys work fine in my first fix gun and the gas has been changed.
Its most likely a problem with either the fan or one of the wires to/from the fan
If you remove the housing you should be able to see it if not a good clean may well be all it needs
