The EAWR requires systems to be maintained to prevent danger or injury, PAT testing is only one method of doing this.
This always intrigues me.
Many people say that 'PAT' is only one method of achieving compliance, but fail to elaborate on what these supposed other methods may entail..
Firstly, it's nice to see someone using the term PAT correctly. The term PAT testing = Portable Appliance Testing Testing.
Would another method of compliance actually be (at a fundamental level) different from 'PAT', as surely any method would need to include such things as visual inspection, earth bond resistance test (for Class I), insulation resistance test, etc.
First of all, as far as I'm aware, within the Legal documents there is no reference to, or definition for a Portable Appliance. The term only appears in the IEE CoP for In-Service Inspections and Testing Of Electrical Equipment.
As Spark123 has pointed out, there are at least four sets of regulations that cover employers duties with respect to work equipment but the EAW Regulations are most commonly quoted as the reason for PAT.
The EAW Regulation 4(2) state:
As maybe necessary to prevent danger, all systems shall be maintained so as to prevent, as far as reasonably practical, such danger.
Regulation 2(1) -
System means an electrical system in which all electrical equipment is, or maybe, electrically connected to a common source of electrical energy and includes such source and such equipment.
Electrical equipment includes
anything used, intended to be used or installed for use, to generate, provide, transmit, transform, rectify, convert, conduct, distribute, control, store, measure or use electrical energy.
So to comply with Regulation 4(2) an employer may need to have a maintenance regime in place for their Systems which would include their Electrical Equipment.
That maintenance regime would be based on a risk assessment for each system and piece of equipment.
So as an example, what maintenance, if any would be required on a general office PC to prevent danger?
Well for a start, if the PC cable is fed from a floor box and the cable does not run through the lid cutout correctly, the cable could get damaged or cut through if someone stands on the lid.
Part of the documented maintenance regime would be to check the cables are dressed out of the floor box correctly. A visual check of the power leads should also be done and if there are signs of damage it could be tested or just replaced.
If the power leads are under peoples feet they could also get damaged so good house keeping should be adopted to prevent this.
IMO this is all that is required for PC’s to prevent danger. I know some people will argue about testing the earth connections but in reality the chances of a PC case becoming live are insignificant. Nearly all are fed via power leads with moulded plugs on each end and in normal use; the chances of the earth becoming disconnected within the PC are almost zero.
The strange this is, most of the high risk appliances are used in the home and not in the office. Take hairdryers, curling tongs, irons and other hand held mains appliances. The cables are always failing due the movement and when they do the spark is right under the user’s wrist.
Anyway, I think the person who introduced the word PAT has now introduced the term “Fixed Wire Testing”…we shall see.
