Hello, hopefully this is quite a straightforward question - basically I'm removing a 2' by 4' approx section of lathe and plaster sloped ceiling so I can sister a damaged rafter (penetrating damp, now cured) and I will be patching the hole with plasterboard fixed to the rafters. The plaster around the hole is sound and painted.
My question is, how do the pros go about finishing a patch so it doesn't show after re-painting? A couple of articles I've seen online recommend joint compound with reinforcing tape around the edges and feathered a few inches past the hole then lightly sanded, does that sound right and can anyone expand on it?
I'm a fairly competent amateur with backing/board and finish, but this will be my first attempt at a big patch. Can I get a reasonable finish without skimming over the lot?
Appreciate any wisdom you can share.
