Hi there
We have a single garage which seems to be a concrete block construction (the blocks even on the inside are a bit 'crumbly' so I'm guessing low density) with rendering/harling on the ouside, down to about 18 inches of brick at the bottom.
The rendering has cracked and fallen off about 2 feet either side of a corner leaving a biggish patch exposed and in need of repair. The rendering seems to have taken away some of the surface of the concrete blocks as it became detached leaving very rough and uneven blocks.
I quite fancy tackling this job myself once it warms up a bit outside and wondered if anyone could offer any advice re how best to avoid all the work being for nothing and the whole lot just falling off a few months later!?
I'm guessing I might need to apply an initial layer of something to the rough exposed blocks before applying the main layer of render?
I'm also not sure how to tackle the corner and get a neat 90 degree finish (although to be honest I'm not that bothered about its appearance, main priority is weather tight)
The garage roof is corrugated metal (?aluminium) nailed onto wooden roof joists. The roof is not watertight at the back where the render came off so I'm guessing that water has maybe got in behind the render then frozen/expanded pushing the render off. I'm guessing that a priority will be to stop the water getting in, so some detective work is also called for.
Anyway, all advice about how best to tackle the job or even pointed in the direction of existing online resources would be very very helpful.
Thanks in advance
Steve
Thanks in advance
Steve
