Situation:
Triton 10.5kW shower supplied by 10mm² T&E cable, in a rented property.
Observations:
1) The CU appears to be a Wylex unit, converted from rewireable carriers to MCBs. Don't know when. The carrier for the MCB supplying the shower (dedicated) is not pushed right in, and one of the legs is bent.
2) The insulation on the phase conductor, very close to its connection fromthe MCB at the CU, has clearly melted at some time in the past.
3) There is clear evidence of corrosion at the screw down terminal on the MCB carrier.
Questions:
1) As a competent and cautious plumber, am I legally permitted to remedy this problem?
2) Is it better to wrap adequate insulation around the melted section, or to replace the damaged section of the phase conductor with a short section of new cable?
3) If the latter, then is this the right thing to be using (although the rating seems to be for a maximum of 6mm² cable).
I'd be grateful to hear from any experienced electrician.
Observations:
Questions:
