Hi all — first post here.
We've just bought our first little "project" house, which we're in the process of renovating. It's a strurdy 1850's terrace and the exterior walls are in-filled stone and in pretty good condition. We've had quite a few experts check the damp situation, and we're lucky in that there's no sign of any major damp problems, which is a relief.
As I've started to strip back the layers of wallpaper and paint, and after chasing out for new electrics, it appears that there are quite a lot of patches of plaster which are blown and crumbling away. The interior walls aren't a problem, as they are brick-built — but I'm trying to work out the best course of action for repairing the patches on the exterior and party walls.
A lot of what I've read about stone-built buildings suggest that lime render is the logical way to go, to allow the walls to breathe properly. But I can't find much to suggest whether or not it's safe to use gypsum plaster or not.
My original thinking was to patch the exposed areas using a base of bonding plaster, and then apply a finishing coat of multi-finish plaster, but I'm a bit wary about doing that if it's going to cause problems with moisture.
Any advice from anyone who's had to do anything similar would be much appreciated.
