Patching up chased walls before a skim
S
sentinal73
I have a living room where I've chased out for speaker cables and fitted 2 new door linings.
I need to patch this up, current plaster is very sandy. House is 1930's.
Is it ok to use hardwall on this?
I do have a plasterer in shortly to skim the room afterwards
Also, have some wooden lintels above the doors which plaster has come away, should i PVA these first before I patch things up
You could use Hardwall but I use Bonding on cable chases as it’ll stick better to cables/cable protectors/boxes etc. Re the timber lintels; plaster won’t stick to wood, it’ll crack & fall off. Screw some strips of plasterboard to the timber first & then use Bonding to fill out to the surrounding wall level. Put a strip of reinforcing tape over all the joins for good measure prior to skimming.
Thanks, will give that a go
do i need to PVA anythign before hand ?
Cheers again
