I live in a very wet part of Lancashire with particularly claggy clay soil that simply refuses to drain. Previous owners put a shed straight onto the soil surface and now, 10 years after moving in, the shed has sunk to such a degree that the floor has made contact with the ground and rotted away, the walls are moving apart and the whole thing is basically knackered.
So I'm buying a new 12 x 8 foot shed and a friend has given me a load of concrete slabs he didn't need. I guess the best solution is to dig down, lay hardcore and then sand and cement on top to create a base to lay the slabs onto, although some people say I could do it without the hardcore.
What I want to know is should I make the patio exactly the size of the shed base, so that water running off the roof doesn't land on the patio, or perhaps I should make the patio ever so slightly dome shaped so that water runs away on all sides?
To make matters more complicated, the old shed was 8 by 6, and the ground slopes down to one of the long sides before levelling off, so this means I'm going to have to dig out a couple of feet to make the flat bit wide enough.
Several times a year, after a heavy shower, water can stand up to, or slightly above, ground level in one corner of the current shed and so I'm going to be putting the new shed 2 feet out over that bit. Obviously my new patio will have to be higher than the current ground level.
