patio door lock
23 Apr 2002
I have a patio door that uses a lever (pushed downwards) to secure it and then a key to finally lock it. The lever has unfortunately snapped does anyone know if this simple thing can be purchased alone without buying a whole new lock? Thanks in advance.
If this is for an older patio door system using a standard type lockset but with a 2" ( short ) backset you are probably out of luck on parts ...... but can get a custom replacement for the handle set from me. I also stock the deadbolts .... one mfg. still makes a replacement.
Stan The Old Hardware Man
Discontinued Amerock Specialist
601-857-8443
