Hello all,
I am laying a patio outside a set of French doors/ windows. The house is pretty old (1856) so the doesn't appear to be a DPC. I have a number of issues that I need to sort but the main area I am looking for advice on is to do with drainage.
Issues:
Historically I have had damp at the door corners and under the floor inside the door- this appears to be mainly due to poor installation of the doors as the sill didn't / doesn't overlap the brick course at the bottom of the door
My main question is : with no DPC do I need to install drainage between the house and the patio I.e a French drain or other. If so do I need to plumb it into a proper drain or can I just pipe it into the ground - I can imagine it will only be a trickle if the patio slopes away from the house.
Also, should I go 2 courses below the patio doors course for the patio level?
Thanks in advance,
David
Issues:
Thanks in advance,
David
