Patio grout gets soft when wet?
21 Oct 2022
Hi all,
I had my patio installed a couple weeks ago and the landscaper used a grout which he brushed in. The problem is everytime is rains the grout seems to gets soft and I can scrape bits out with my finger - Is this normal? I also noticed one of the slabs (limestone) seems to have cracked, which wasn't there the other day and nothing has been dropped on it. What could cause this? There hasn't been any ice or frost, just sun and rain.
Thanks!
The picture Mike has linked is what is likely under your slabs. Using dabs means there are effectively a few blobs of concrete under each slab, which means if you step between the blobs there is no support = extra stress on the slab which leads to the crack. The blobs are easier cheaper and faster to lay, but clearly not the way it should be done.
