Hi.
I've had my house renovated and I'm moving onto the back yard as a DIY project because, well, the money had to run out sometime. It's only a small back yard, about 2.5m x 6m. Double french door now open onto the short edge, and more from the kitchen along the long edge. The other long edge is the fence to the neighbour's, the short end is the fence and gate to the back street. Although the decision hasn't been made about paving, it may be slate tiles, so it will possibly be mortared in.
Due to the changes in planning laws over time I now have a brick manhole in the centre of it that wasn't necessary before I had the renovation: 1200 x 750, covered with a concrete slab and inset with a square manhole cover. I've been digging up the site to level it and it appears the manhole cover is level with one brick below the DPC. I've read around and know that ideally any solid surface should be 150mm, two bricks, below the DPC. Sites such as pavingexpert.com show various methods to drain paving areas higher than 150mm above the DPC, including channel drains and linear drains.
My questions are: how should I drain the area? Do I NEED to drain the area (it certainly wasn't before with no apparent ill effects)? I haven't got a concrete base, just hardcore and the clay/earth that the builders dug through to find my drains (pretty much the whole yard!). I could slope towards my wall and use a linear drain (I have a surface water drain I can run into in one corner) but how can I accommodate the manhole into the slope?
Added to this is the fact I'm getting a new fence this week and I need to set the base level for it first. My neighbour's old patio is only a brick and a half below their DPC so ideally I should be starting there at the fence line, but I can't slope towards the neighbours or just on to the street (those planning laws again).
Basically, any pointers appreciated, or else I'll make it up as I go along based on what I find on Google or in the Reader's Digest DIY Manual! (This is generally how I get through these things - I haven't done so badly so far. Usually. )
Thanks in advance for any help.
Cheers.
Cheers.
