Patio - level with dwarf wall DCP?please advise re B Reg's
11 Apr 2009
Coventry
Hi there.
sorry had to repeat this OP as no one has left any replies so i think I may do better in the Building Section of this forum
I am looking at doing our patio this summer and simply need to know can i lay the patio upto the same level where the DPC is of the dwarf consevatory wall? ( to which the patio door frame sits on the DPC ) so I am looking for upto as close as i can get to the same level as the internal floors but I am happy to go below if needs be. I am just wanting to have the doors open in the summer and simply walk out onto a similar level of the house and avoid any step as such, but still have the door frame to step over.
I will be looking at laying a drainage system along the bottom up against the dwarf wall where the patio slabs and wall meet! ( aprox 6 mrts long ) so there is going to be a 90mm gap or so for rain water to run into the FloPlast drainage system
and i shall also run the patio away from the house/conservatory
is there an BuildReg issue with splash back from rain dropplets? as I read somewhere ( dated some 4 years ago ) that there is a 150mm rule for this problem?
but in fancy new homes they have the internal flooring and doors level.. with the patio slabs? so i am wondering how do they do this
simply need advice as to what i can do re any building reg's that i need to follow
Cheers All
Jim
Read more: //www.diynot.com/forums/buildi...radvice-re-dwaf-walldpc.328771/#ixzz1z6rpXgQc
hi there.
cheers for letting me know and many thanks.
sorry for repeating my OP before
I have looked into the planning regs, and it states that it must be 150mm below DPC line due to rain splash! but it does not state nor say anything relating to a patio/hard standing up to a building
please can someone advise
The short answer is that building regs do not apply, so you can do what you like with the levels
150mm is "recommended" to deal with rain splashes, but if you have a cavity wall it does not matter how high water splashes up
Hi Woody
many thanks for getting back to me on this
i had thought so, but needed someone to confirm it. cheers again as always you have come up with the goods
many thanks
J
