I'm planning to plaster an interior block wall in my garage. At the same time I hope to replace the surface-mount light switches with standard flush ones and bury the wiring in the plaster (protected by metal conduit). If I go by the plaster manufacturer's recommended thickness, that will be about 11mm bond coat followed by 2 or 3mm multifinish. Typical back boxes start from around 25mm depth, so if I mount the back box onto the block surface, it will be >10mm proud of the finished wall.
I must be missing something! What is the correct way to do this? Am I supposed to chop the back boxes into the block wall to get the desired depth? Seems like a lot of work for what must be a common thing to have to do.
Thank-you very much!
