I've just bought a new patio set and at the moment my patio area is 10mm gravel between 2 - 3 inches in depth bounded by a concrete path and a low wall.
Having thought about the chance of damaging the new furniture by dragging it through the gravel each time I use it, I thought it may be a better idea to put some form of hard surfacing in place. The option I was going for was to lay slabs over the area (planning on being around 3m x 3m).
When laying the new slabs, I want them to be level with the existing concrete path and in a bid to save a bit of cash, can I lay them on the existing gravel? Would I need to bed them on mortar to hold them in place better? I am debating what to use in the gaps between the slabs, and whether to have short joints of around 10mm and point it with mortar or to have 50mm joints filled with gravel held in with coloured mortar.
Obviously the cheaper option would be to have the larger gaps as it would reduce the number of slabs I need.
I do have a few existing slabs that I can use to lay on the ground to raise the level in the lower areas and then lay the new slabs on top.
I think that's it, what are your opinions of my plans? I know it's not the best way to do it, but is this going to work or likely to fail by Autumn?!!
Thank you!
Thank you!
