Paving slabs over concrete
23 Aug 2017
i have a concrete slab that is solid and doesn't need replacing but the garage on top does. We are replacing it with a log cabin but it's 2cm to wide
Could I lay slabs over the concrete slab to give extra width required? How would I do it?
if it's wider than the slab that's good, it will prevent water running onto the slab and making the ground beams wet.
20mm is nothing to worry about, as John says + keep the surrounding ground a little lower than the slab.
You can lay over the top or just add to the side. Lay slabs with a solid bed if laying over the top.
