Paving slabs with hard core
14 Apr 2017
Hi guys
I am in the midst of a garage build, and I know that for hard core one should use rubble that is around >= 20mm. What about concrete paving slabs? I've got quite a lot intact ones (350mm x 350mm x 10mm) sitting around, and it'll be a bit of a waste if I have to dispose of them. I was thinking of using them intact along with hardcore to fill in the gaps to make a nice flat base.
Yay or nay?
You'd have to break them up quite a bit first because you need the hardcore to all lock together without big voids. I tried that with some bricks from a wall and quickly changed my mind due to the effort.
Hmm, did you try spacing the bricks out? and were they intact or already a little broken/jagged ?
What's the rational behind hardcore anyway ?
As long as your have enough depth either below or ontop and they are fully supported you wont have a problem.
If you use bricks space them out and fill the gaps with 2" down.
